In Enhance Colors, I set Brightness, Contrast, Gamma: 80, 0, 0.50.
In Batch Convert Adjust, for the same effect, I need Brightness, Contrast, Gamma: 30 or 34, 0, 0.50.
The difference is in Brightness. It is not even clear how what I do have to set in Batch Convert, something between 30 and 34, to match the 80 from Enhance Colors.. See the example screen shots,with Preview.
+Additionally, in Batch Convert I cannot use Presets that I saved in Enhance Colors (or Presets, that I saved in Curves).
Enhance Colors: (note Brightness =80, Contrast, Gamma)
Batch Convert Adjust: (note Brightness =80, Contrast, Gamma.)
Batch Convert Adjust: (note Brightness =30, Contrast, Gamma. )
Parameters in Enhance Colors and Batch Convert Adjust different
Peter26mar2023
Re: Parameters in Enhance Colors and Batch Convert Adjust different
yes, batch convert adjust was not modified
