1.9.3: Info is not updated in multiselect
moropus
Post by moropus »
XnView: MP 1.9.3 - 64 bit
OS: Windows 10 64bit
Info panel for the selected image is not updated while switching from multiselection to single selection.
1. Have multiple files in folder (A.jpg, B.jpg)
2. Open Browser. View panels: Preview and Info
3. Select the first image A
4. Select image B with shift/ctrl so both images are now selected
5. Notice that Preview now shows the last selected image B, and Info is empty (which is OK)
6. Click on the last selected image B to select it exclusively
Actual behaviour (bug):
- Info panel is still empty
Expected behaviour:
- Info panel shows information for the selected image B
This behavior only occurs if you re-select the last selected image in selection.
Re: 1.9.3: Info is not updated in multiselect
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
moropus
Post by moropus »
Fixed in 1.9.7
