Hi )
I can not understand why in WEBP quality 100% does not mean lossless quality, but select lossless quality means lossless quality, why this so?
I select quality, and there not said what I select only lossy mode, because I think what this misleads )
I offer rename mode quality to lossy mode )
Tested in XnView MP 1.93 )
WEBP
WinnieW
Re: WEBP
I guess the WEBP developers use the same settings like JPEG,
set JPEG encoder to 100% quality means lossy compression, too.
The only difference is that WEBP has an additional lossless compression algorithm, which JPEG has not.
It might be confusing to users that a 100% setting doesn't mean lossless but highest lossy quality instead.
Xn User
Re: WEBP
Yes , this so , but you need remember what JPEG never not was be lossless , and this means what we can say only quality in lossy mode , and because yes , values from 0 to 100 where 100 maximum quality of lossy quality ) , but in WebP available both mode , lossy and lossless , however quality range from 0 to 100 mean what 100 this maximum quality from codec , and this lossless mode ) because need explain where is it about select quality only lossy mode )
Xn User
Re: WEBP
I suppose what quality range 1-100 was make when absent lossless methods , then yes , range 1-100 mean what 100 this best quality ) but after add lossless methods compression value 100 and value lossless should be identical , otherwise I methods need split to lossless and lossy and about this need say in process select method ) If this not do , then I can not understand , which idiot think is what quality without explanations what this lossy mode with 100 not same as lossless quality mode )
And this misleads in more software , often developers create plugin and think what value of quality 100 this is lossless
moreover in ACDSee still quality 100 and lossless identical , but both mode is lossy
