UI inconsistency
Bugs which are supposed to be fixed in the next test version (not available yet)
artsi
UI inconsistency
Post by artsi »
I'm on XnViewMP 1.9.3 and I don't like the star ratings. For me a 1 start is keep and a 2 star is good...
So I changed them in xnview.ini (with xnviewmp closed) to:
ratingLabel=Unrated, Keep, Good, Like, Excellent, Outstanding
It works in the catalog filter by displaying the correct labels
but when assigning star rating, metadata > set rating > it's ignored and the ratings are back to poor -> excellent
BTW, I have included screen captures with google drive but they do no show in the preview.
Thanks
Re: UI inconsistency
artsi
Post by artsi »
xnview wrote: Wed Aug 20, 2025 1:52 pm :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
Thank you
