Viewer - auto zoom
'Fit image to desktop' does not change the size of the image when fitting it to the desktop
expected behaviour
- Fit Image to Desktop (adjust image to fit screen)
- image size
- image is always fully visible, but its size changes (up/down) according to the size of the desktop ⬅ issue here
(like Fit option in 'Set wallpaper' tool or 'Fit image to window' with maximized window)
- window
- size
stretches to accommodate resized image (keeping empty area of viewport to a minimum)
- position
- Viewer tab
- in Xnview Classic/MP window anchors to the center of the screen
which annoyingly reposition app when navigating through files of different sizes
- in IrfanView - to the top-left corner of the screen
which eliminates app window jumping on the screen
- Browser tab
- opens at its previous position
- Viewer tab
- size
- image size
- Fit Window to Image (adjust window to fit image)
- image size
- 100%
- window
same as in mode above
- image size
Related
- issues
- todo -
1.9.3 - viewer - auto zoom - 'Fit image to desktop' does not fit (current post)
1.5.5 - viewer - pan - issues with selection/zoom/fullscreen
- fixed -
1.9.8 - viewer - auto zoom - normal mode affects fullscreen (1.10.1)
1.8.3 - viewer - auto zoom - resets to 'No fit' (1.9.4)
1.7.1 - viewer - auto zoom - fit image to desktop issues (1.7.2)
1.4.4 - viewer - auto zoom - mode inherits from fullscreen (1.4.5)
