Search Dialog question
jkm
Post by jkm »
Is there a way in the Search dialog (Ctrl-F) to search against all files in the catalog, regardless of folder/location?
If I leave the Folder field empty, XnViewMP does one of two things:
- If I have search in catalog only checked, it instantly tells me there are zero results, even if there are many files in the catalog that match the search.
- If I have search in catalog only UNchecked, it starts searching every folder on the drive where XnViewMP is installed.
The first behavior seems wrong, and the second behavior is not what I want. Putting * in the folder field does not help.
So the search box seems obsessed with only searching in a particular folder and its subdirectories. This has consequences:
If you have files on multiple drives, a single search cannot find them, even if they are in the catalog!
If you have files in two equal level folders in the root directory (like V:\Photos1 and V:\Photos2) then you cannot search them both without searching the entire V drive.
Am I missing something here or doing something wrong? If there is actually no way to search the entire catalog and not just one folder in it, that seems very bad.
Thanks for any clarity that can be provided...
Re: Search Dialog question
right folder field can't be empty
jkm
Post by jkm »
So in your fix, if "Search in catalog only" is CHECKED, and folder field is EMPTY, then filename *.TIFF will find all TIFF files currently in the catalog, regardless of location?
And if "Search in catalog only" is NOT CHECKED, what is the behavior of an empty folder field supposed to be? Does it search the boot drive, or the drive XnViewMP is installed on, or all mounted drives?
jkm wrote: Wed Aug 27, 2025 6:30 pm So in your fix, if "Search in catalog only" is CHECKED, and folder field is EMPTY, then filename *.TIFF will find all TIFF files currently in the catalog, regardless of location?
yes
it starts on current folder
jkm
Post by jkm »
That sounds excellent. Thank you!
jkm
Post by jkm »
xnview wrote: Fri Aug 29, 2025 6:53 am
Pierre, I just checked this, and this fix does not seem to be implemented in the 8/27 build.
An empty folder field with "Search in catalog only" NOT checked starts searching in \ (the root directory).
As you said above, it should search current folder.
"Search in catalog only" does work correctly in that build though, so that part is fixed.
jkm wrote: Fri Sep 05, 2025 6:31 am Pierre, I just checked this, and this fix does not seem to be implemented in the 8/27 build.
yes will be fixed
This problem is supposed to be fixed in XnView MP 1.9.4. Please check and confirm the bug fix here.
jkm
Post by jkm »
Yes, this is fixed.
