Linux - Mouse problem with full screen
KATERchen
Post by KATERchen »
Hello
I am a switcher from Windows and would like to continue using XN View in Ubuntu 24.04 with KDE. In the full-screen mode, however, I have the problem that two to three images are always scrolled at the same time when searching with the mouse wheel. I didn't find anything about it in the settings. The arrows from the tool bar work. I'm using an original MX-Master with Logiops. But the problem also occurs with the Ubuntu default settings.
jkm
Re: Linux - Mouse problem with full screen
Post by jkm »
On windows, you are able to adjust the scroll speed of the mouse on a per-application basis. You might check if you can do this on Linux.
You can definitely adjust scroll speed globally:
https://github.com/PixlOne/logiops/issues/116
KATERchen
Post by KATERchen »
While this affects the entire system, strangely enough, it doesn't affect XnView. There, multiple images are still scrolled simultaneously.
KATERchen
Post by KATERchen »
Hallo,
da die Webseite in perfektem Deutsch ist hoffe ich einfach mal, dass Du das gut verstehst. Mein englisch ginge nämlich nur über ein Tool und würde die Kommunikation etwas schwieriger gestalten.
Tatsächlich ist das Scroll-Problem das Einzige, was mich im Moment noch von einem kompletten Umstieg auf Linux abhält.
Gerade hatte ich eine interessante Sitzung mit ChatGPT, der hat mir erst mal das mitgegeben:
Current Setup (Linux + MX Master 3S)
Mouse: Logitech MX Master 3S
Driver/Tool: logid
OS: Linux (KDE/Xorg)
logid configuration highlights:
hiresscroll:
    hires: false;        # High-resolution scroll disabled
    invert: false;
    target: false;
    up: {
        mode: "Axis";
        axis: "REL_WHEEL";
        axis_multiplier: 8;
    down: {
        mode: "Axis";
        axis: "REL_WHEEL";
        axis_multiplier: -8;
Behavior observed:
Scroll works globally in Linux apps (Firefox, etc.)
In XnView MP: exactly 8 wheel ticks are needed to advance to the next image
Changing axis_multiplier affects other apps but does not reduce the number of ticks per image in XnView
HiRes scroll (hires: true) causes multiple images to skip at once
Issue:
XnView MP interprets the standard wheel ticks internally, grouping multiple ticks before advancing one image. There is currently no way via Logid or OS-level settings to achieve true “1 tick = 1 image” scrolling under Linux.
Request / Suggestion:
Could XnView MP provide a configuration option to adjust the number of wheel ticks per image, similar to “Lines per Wheel Tick” in some Windows versions?
This would allow smoother, precise image-by-image scrolling with high-resolution mice like the MX Master 3S on Linux.
Ich hoffe, Du kannst damit etwas anfangen.
Letztlich behauptet ChatGPT, dass viele Linux-Nutzer das Problem haben (ich selbst habe darüber tatsächlich aber nichts gefunden) und das die wohl einfachste Möglichkeit wäre, wenn Du Programmseitig etwas ändern könntest, da gerade Logitch-Mäuse immer wieder Probleme unter Linux haben.
Wenn Du Lust und Zeit hast, da etwas zu ändern, würde ich mich als Tester anbieten. Vom Programmieren habe ich leider keine Ahnung :)
KATERchen
Post by KATERchen »
Unter KDE 6 mit der Version 1.11.7 besteht das Problem nicht. Mit der Version 1.12.2 ist es aber wieder vorhanden.
This problem is supposed to be fixed in XnView MP 1.12.3. Please check and confirm the bug fix here.
KATERchen
Post by KATERchen »
Danke für die Arbeit. :)
Im Vollbildmodus funktioniert es jetzt wieder, in der Thumbnail-Ansicht aber noch nicht. Außerdem, wenn ich dort am Scrollbalken den Pfeil nach oben oder unten klicke, werden die Thumbnails nur um ein paar Pixel weitergescrollt.
Thanks for the work. :)
It’s working again in full-screen mode, but not yet in the thumbnail view. Also, when I click the up or down arrow on the scroll bar there, the thumbnails only scroll by a few pixels.
