XNviewMP 1.9.4 with bug in Copy and Paste resource
josedumoretzsohn
Copy and Paste in 1.9.4, differently from 1.9.3, is not allowing to Paste into Selection. It always pastes in the center of the chosen image. Until 1.9.3, to which I returned, on a same image we could select a piece of image, copy it with Ctrl+C, move the selection to another place on the same image and press Ctrl+V to print the copied piece. Now, in 1.9.4, when we press Ctrl+V in this last step, a new print shows exactly in the center of the image, with a slightly darker color than the original, therefore disabling its use.
Re: XNviewMP 1.9.4 with bug in Copy and Paste resource
you can move it round, also toolbar appears on topjosedumoretzsohn wrote: Fri Oct 03, 2025 8:45 am in 1.9.4, when we press Ctrl+V in this last step, a new print shows exactly in the center of the image
I cannot reproduce, color is the same
NicoGT
I face the same, this is CRITICAL to me. The old behaviour was much useful.
Now I need to go back to 1.9.3 to retrieve it.
Often when I Copy Paste, I want to be able to paste at the same place and stretch it.
JustPassingByToSayHi
I second that the new behavior is completely terrible. It has made simple copy-pasting unnecessarily tedious. Why the heck would I "move it around" and click extra buttons when all I want is whatever's in my clipboard pasted into the selection I made?
At the very least, give us a way to switch back to the old behavior. I had to roll back to 1.9.3 for now...
josedumoretzsohn
I went back to MP 1.9.3 too. In 1.9.4, although we can move the new print around as I wish and place it where desirable, in my case the color is slightly darker indeed, and this turns the new paste useless.
Besides, in 1.9.3 we can do all this process in the same image: (1) select a piece, (2) copy the selection with Ctrl+C: (3) move the selection frame to the new desired place, and (4) press Ctrl+V to paste the copied piece there. It will show exactly like it was before. Additionally, I don't see this possibility mentioned anywhere else in this Forum.
I hope you will return to the 1.9.3 routine.
Check the opacity valuejosedumoretzsohn wrote: Sat Oct 04, 2025 11:15 am I went back to MP 1.9.3 too. In 1.9.4, although we can move the new print around as I wish and place it where desirable, in my case the color is slightly darker indeed, and this turns the new paste useless.
Selection will be used in next release...
Thanks to your detailed description I can reproduce the problem.
user555
Thank you, Pierre. Copy Paste with free ratio is very important to me. I use it a lot to stretch border areas.
josedumoretzsohn
Please, how do I get rid of the four anchors around the newly pasted selection, to save the new image?
josedumoretzsohn
Sorry, I hadn't seen the rewsource toolbar above.
josedumoretzsohn
Yes ! Exact color was achieved with Opacity 5. Thank you. However, I would suggest to keep on the possibility of copying and pasting on the same image. (1) Frame the piece to copy; (2) Ctrl+C; (3) Move the selection frame to the desired place; (4) Ctrl+V. Thank you again.xnview wrote: Sat Oct 04, 2025 2:01 pmCheck the opacity valuejosedumoretzsohn wrote: Sat Oct 04, 2025 11:15 am I went back to MP 1.9.3 too. In 1.9.4, although we can move the new print around as I wish and place it where desirable, in my case the color is slightly darker indeed, and this turns the new paste useless.
mguarra
Same for me, it's a fundamental feature. I also had to go back to 1.9.3. The new method of cutting and pasting image portions is completely unusable for me. Thanks.NicoGT wrote: Fri Oct 03, 2025 1:07 pm I face the same, this is CRITICAL to me. The old behaviour was much useful.
This problem is supposed to be fixed in XnView MP 1.9.5. Please check and confirm the bug fix here.
josedumoretzsohn
I am trying to cope with 1.9.5, but the Paste-resulted image is still much darker than the piece selected and copied, and in 1.9.5 there's no Toolbar where to manage the Opacity value. So, please, would you teach me where to find it in the menus. Could it bear a different name in any specific menu? Thank you for your guidance.
