When renaming a folder with a dot in it, XnView MP UI mistakenly consider the part after the dot the extension and put it in a separate input control, makes renaming confusing and inconvenient:
When the renaming target is a folder, it should never try to split it into stem and suffix.
1.9.5: Renaming a folder shouldn't attempt to split ext
fireattack
Re: 1.9.5: Renaming a folder shouldn't attempt to split ext
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
