Histogram seems broken in Browse
astrofalcon
Post by astrofalcon »
Just wanted to report that I'm not seeing / getting a working histogram when in the Browser mode. This is a fresh install of XnView on my Windows 11 system.
Re: Histogram seems broken in Browse
Browser > View > Info panels > Show histogram selected?
astrofalcon
Thank for the quick response! But yeah, checked and still nothing...
jkm
Post by jkm »
Try downloading a fresh copy of the app, preferably the portable (zip) version.
Run it with a clean .ini file and database, and see if the histogram works. If it does, something’s wrong with your current installation or settings.
astrofalcon
Thank you Pierre for taking a look into this so quickly! Glad to hear you were able to reproduce this and to know it was not something going on with my installation specifically. I'll keep and eye out for an update.
Drakemoor
Post by Drakemoor »
I just want to add that the histogram that's part of the Info panel works for me, but also the histogram that has a separate panel does not.
Clipboard Image.png (535.09 KiB) Viewed 80 times
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
