Settings - Integration - improve UAC elevation handling
XnViewMP 1.9.5
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
  • improve UAC elevation handling
    current behavior
    0. start app w/o admin rights
    1. change "Add 'Browser with XnViewMP' to context menu" checkbox
    2. press OK
    nothing happens, setting remain unchanged w/o notifying user
    expected behavior
    like in FastStone:
    1. check checkbox that require admin rights
    2. press OK
    UAC popup appears
Example
  • FastStone
Related
Re: Settings - Integration - improve UAC elevation handling
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
done in 196
