I've been using XnView MP for a long time, and since an update, the behavior has changed when assigning categories to photos. The search function did not return any relevant results, but is there a possible solution for this?
I have a catalog with over 1000 keywords. Until now, when searching for a keyword, I was first taken to the correct position in the catalog, where I was able to select it.
Now, when selecting a search result, the category is selected directly. This is a bit odd, as I may have to exclude subcategories and would therefore like to be directed to the catalog entry as before.
Is there a known workaround for this? I'm using version 1.9.5 (64-bit).
Thanks in advance!
Cheers
dom_98
Category selection behavior has changed
Re: Category selection behavior has changed
which version do you had? the category was not selected???dom_98 wrote: Thu Nov 06, 2025 10:35 am Now, when selecting a search result, the category is selected directly. This is a bit odd, as I may have to exclude subcategories and would therefore like to be directed to the catalog entry as before.
dom_98
Hi Pierre,
thanks for your reply. I don't know the exact version I had back then, but I assume it's at least 2-3 years old.
In the old version, the list would always jump to the category entry I had found using the search function, but in the new version, it doesn’t do that anymore. Strangely, this only started happening after I upgraded to Windows 11, although I also had to reinstall XnView at that time.
you can change behavior in the menu (on right) Action>Open tree
dom_98
Worked, thanks!!
