RGB adjustements highly non-linear
oayz
Post by oayz »
May not be a bug but a feature :-) In RGB ajustements:
0-50 basically make no effect, somewhere around 70 it starts to actually adjust color, around 100 become visible:
Here is the example:
R, R_agjust, new_R:
64, 0-50, 64 (no change !!!)
64, 0-60, 65
64, 70-80, 66
64, 100, 67
64, 120, 70
64, 140, 75
64, 160, 79
64, 180, 86
64, 200, 94
64, 220, 104
Adjustment curve is highly non-linear and not as expected. Normally we either increase RGB by %% ( +/-100%) or by value (+/- 255)
BTW, I believe it's a regression for quite a few releases
Re: RGB adjustements highly non-linear
it has been changed in 181
yep, some adjustments are welcome
  • calculation
    - revert calc to the one from 180 for RGB sliders in Enhance colors
    Color balance in Batch convert works as expected
  • scale's UOM
    - maybe change scales to % (w/o % indicator) for Brightness/Contrast, RGB, Hue, eg like in Affinity/Ps
    Percentage scale seems more intuitive and I just don't see advantages of using an integer scale (255 and 127 (255/2)).
    Example
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
