1.9.5 - browser - thumbnails - issue with thumbnails generation
XnViewMP 1.9.5
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Browser - thumbnails
there is some issue with thumbnails generation (test files)
case A
  1. t from t file via exiftool
    it works - OK
  2. XnViewMP can read,rotate,delete,rebuild
case B
  1. t from source file itself via exiftool
    Warning: [minor] Writing multi-segment EXIF - OK-ish ?
    Note: unfortunately exiftool cannot automatically generate resized thumbnail from main image,
    so file size became twice bigger. Not sure if it is still valid tbh.
  2. open folder in Browser
    XnViewMP shows t in Exif info tab, but
    ignores this embedded thumbnail, does not show overlay icon and cannot rebuild
case C
  1. t via XnViewMP
    1. open 'orig' folder in Browser
    2. select files and press 'EXIF thumbnail - Rebuild' command
    nothing happens
Related
Re: 1.9.5 - browser - thumbnails - issue with thumbnails generation
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
fixed in 196
