Update metadatas
jlrjlr
Update metadatas
Post by jlrjlr »
Many thanks for this explanation, I was looking for it! The new Date and Exif trees looks promising. Thanks Pierre for this always improving tool.
But What did I do wrong ?
when I press on "Update metadata" after selecting all my directories a small panel appears very briefly then disappear. The trees are not populated.
I am running xnView 1.9.5 on W11
jkm
Re: Questions/Comments on New Features in 1.9.4
Post by jkm »
Have you tried exiting and restarting the app?
jlrjlr
Post by jlrjlr »
Thanks for your answer
Did I restart : Yes many times. I started the trial with 1.9.4
v1nc3
Post by v1nc3 »
In order to populate this information in the Catalog Filter, your database must be updated. Go to Settings:Catalog and you will see an "Update Metadata" button in the lower right corner. Clicking this button will only update metadata for the folder that is currently selected in the directory list on this screen. So to update the entire database, select all the directories in the list (by clicking on one and then hitting Ctrl-A to select all, or clicking on the first one and then shift-clicking on the last one to select all) and then once all the directories are highlighted, click the "Update Metadata" button. This process will take a short time.
I've done this quite a few times and I keep getting that stupid message to update the catalog every time XnviewMP launches. Every. Single. Time. From 1.9.4 to the current 1.95. It never goes away.
jkm
Post by jkm »
v1nc3 wrote: Sun Oct 26, 2025 4:02 am I've done this quite a few times and I keep getting that stupid message to update the catalog every time XnviewMP launches. Every. Single. Time. From 1.9.4 to the current 1.95. It never goes away.
On what OS? Make sure your xnview.db and xnview.ini are not read-only. If on Windows, try running XnViewMP as administrator to circumvent any permissions problems.
If you have run it multiple times, you should see several files with names starting with XnView-2025_xxx.db in the folder where your xnview.ini file is located. How many such files do you see?
jkm
Post by jkm »
jlrjlr wrote: Mon Oct 20, 2025 8:36 am Thanks for your answer
I haven't seen that happen. There's nothing under Date or Properties at all?
Are you sure your files have the appropriate metadata?
Please post a screenshot of your catalog filter pane showing the Date and Properties trees, and a screenshot of the Exiftool tab in the Info Panel showing the "EXIF" section for one of your files.
jlrjlr
Post by jlrjlr »
Thanks for your answer and sorry for this late reply, I was away from keyboards for a while
catalog filter pan
info "EXIF" section
Param Catalog
In my config "base directory" is not empty (I run XnViex on my C: drive but also X: drive a NAS or usb stick )
Ok, there is an issue when 'base path' is used
Re: Update metadatas
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
jlrjlr
Post by jlrjlr »
Perfect XnView 1.9.6 solves the issue. :D
The new filters "date" and "properies" are great. It helps me a lot managing old family photos
Thanks for your hard work and great ideas.
