I would like to report an issue regarding Clip Studio Paint file thumbnails not displaying on Linux x64 release in version 1.9.4. I am using XnViewMP on Debian 13.
- There is an earlier report describing the same problem where Clip Studio Paint thumbnails were not working: viewtopic.php?t=38583
- It was later stated that this issue had been fixed in an earlier version: https://www.xnview.com/mantisbt/view.php?id=1997
However, this fix appears to apply to macOS only. On Linux, Clip Studio Paint thumbnails still do not work.
It was mentioned that a plugin should exist to enable Clip Studio Paint thumbnail support, but no such plugin is available on the Linux platform. In fact, the plugins dialog shows no plugins listed at all.
Could you kindly clarify the current state of this feature on Linux? Is there an existing fix or planned solution for Clip Studio Paint thumbnail support on this platform?
Bug Report: Clip Studio Paint Thumbnails Not Working on Linux (v1.9.4)
caiwan
Re: Bug Report: Clip Studio Paint Thumbnails Not Working on Linux (v1.9.4)
please send a sample file
