XnConvert not remembering output settings on Mac
unabatedshagie
Post by unabatedshagie »
No matter what I seem to do XnConvert will not remember the output, filename or format settings I select.
Every time I open the app I have to change them. This wasn't an issue when I was using Windows.
If I look at the contents of .xbs file I saved I can see all the settings are what I had set when I saved the preset.
Re: XnConvert not remembering output settings on Mac
version 1.106?
unabatedshagie
1.104 which is the latest version on the app store.
I've tried the App Store version, and no problem. MacOS intel or ARM?
unabatedshagie
It's a Mac Mini M4 so I assume that's Intel.
I downloaded the latest 1.106.0 DMG straight from the site and that seems to be saving the options on a restart.
