Linux & Windows versions work different when it comes to Cutting & Pasting:
1) Select some area on an image
2) Cut it with Ctrl+X
3) Move the selection to some other place on the image
4) Paste with Ctrl+V
In Linux you paste the contents exactly in this moved-to-some-other-place selection.
In Windows it is pasted just randomly (I guess) regardless of the selection.
Can anyone confirm this?
P.S. Also, a question: where can I set more undo levels in the program?
Thank you.
Cut & Paste selection in different OS [SOLVED]
TheExplorer
Re: Cut & Paste selection in different OS
It's the same behavior, Do you have the Paste bar?TheExplorer wrote: Sat Dec 13, 2025 1:09 pm Linux & Windows versions work different when it comes to Cutting & Pasting:
TheExplorer
Are you sure you're cutting and not copying in windows?
Not sure what is it. I rarely use Windows actually, but when I do I need a nice image editor.Do you have the Paste bar?
Anyway, I guess we may consider it closed since copying and pasting works okay.
It's not the same when cutting??TheExplorer wrote: Mon Dec 15, 2025 4:05 pm Anyway, I guess we may consider it closed since copying and pasting works okay.
TheExplorer
Damn, some miracles happening here on this Win10 machine. Re-downloaded the latest 1.9.8 .zip package and now it is doing what it should. No more glitches. Thank you for your patience, time and support. I'm sorry. Marking as solved.
