Hi!
I am trying to run NConvert on macos to no avail.
Whenever I run the command, I get a system popup stating that the library xxxx "can’t be opened because Apple cannot check it for malicious software" (see attached). The command fails to run.
PS: Works fine on Windows.
* OS: Sonoma 14.5
* NConvert v7.110 (Downloaded on Dec 10th 2025)
Thanks in advance for your help!
[HELP] Apple cannot check it for malicious software!
odurand75
Re: [HELP] Apple cannot check it for malicious software!
strange, on Sequoai, i've checked and all dylib are signed correctly
odurand75
OK. Let me know if I can be of any help at all by providing more information.
in settings>Privacy you can authorize it. If you tryodurand75 wrote: Fri Dec 19, 2025 6:47 am OK. Let me know if I can be of any help at all by providing more information.
codesign -dv libwebp.dylib
