v1.9.10 Tags will not update
alee001
Post by alee001 »
Bub exhibits the following issues:
1) Browsing displays tags for images created by others in other software.
2) After deleting all (or multiple) tags in the category,
3) The images still display the tags.
4) Even pressing F5 to update does not remove the tags.
Finally, exiting and re-entering the folder is required to clear all tags.
Re: v1.9.10 Tags will not update
when removing categories from panel, files will not be updated only catalog
alee001
Post by alee001 »
xnview wrote: Fri Jan 30, 2026 8:21 am when removing categories from panel, files will not be updated only catalog
Normally, when a category tag is deleted, the tags of the related files will also be deleted and updated; this has always been the case in previous MP versions.
alee001 wrote: Fri Jan 30, 2026 1:12 pm Normally, when a category tag is deleted, the tags of the related files will also be deleted and updated; this has always been the case in previous MP versions.
no, never
alee001
Post by alee001 »
xnview wrote: Fri Jan 30, 2026 1:25 pm
no, never
Unless the new version changes the rules, previous versions are correct.
you delete the category in 'category filter' or you unselect it in Category panel?
alee001
Post by alee001 »
xnview wrote: Fri Jan 30, 2026 2:17 pm you delete the category in 'category filter' or you unselect it in Category panel?
I edit all the tags in the category panel.
Sorry but i dont understand. Please send screenshots (in english)
alee001
Post by alee001 »
xnview wrote: Fri Jan 30, 2026 3:42 pm Sorry but i dont understand. Please send screenshots (in english)
alee001 wrote: Thu Jan 29, 2026 8:33 am 2) After deleting all (or multiple) tags in the category,
when you delete category in Category pane it just delete it from app db
if you want to remove keyword from image you have to:
- unassign it and write changes (if you disabled default auto-export for keywords) OR
- use 'Clean metadata' dialog
search forum for how to use categories
alee001
Post by alee001 »
user0 wrote: Fri Jan 30, 2026 3:56 pm
I've tried deleting images from within their categories in the image metadata, but the tags don't update.
Other people's batches of images contain multiple categories; the only solution is to delete them in bulk from the control panel.
it was always like that...
alee001
Post by alee001 »
xnview wrote: Fri Jan 30, 2026 4:59 pm it was always like that...
v1.9.8 updates normally, but v1.9.10 always has problems.
alee001 wrote: Fri Jan 30, 2026 5:25 pm v1.9.8 updates normally, but v1.9.10 always has problems.
1.9.8 doesn't update files, you can try by installing old version
alee001
Post by alee001 »
xnview wrote: Sat Jan 31, 2026 7:16 am
v1.9.8 does not have this problem. Am I supposed to use an older version to solve it?
