User commands - rework
XnViewMP 1.9.10
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
User commands
there are few inconveniencies
  • not possible to
    - assign custom shortcut
    - add to context menu
    - add to custom filter - open with
    - modify XMP/IPTC template button after initial assignment (bug)
  • functionality spread across app and stored in different places
    • custom Toolbar button (Settings>Toolbar)
      default.bar (also no unique command name)
      _cmd_=name_1;fullpath_1;fullpath_icon_1
      _cmd_=name_2;fullpath_2;fullpath_icon_2
      _xmp_=name_1;fullpath_1;fullpath_icon_1
      _xmp_=name_2;fullpath_2;fullpath_icon_2
    • custom 'Open with' command
      xnview.ini
      OpenWith=fullpath_1, fullpath_2
      OpenWithName=name_1, name_2
      OpenWithParam=arg_1, arg_2
  • unify UI
    • add new 'User commands' section in Settings>Interface(?)
      user commands should be accessible in the list of Toolbar, Context menu, Shortcuts tabs (and Open with, if selected)
    • add new 'Edit user command' dialog
      - (if required) add 'Type' field [Executable (.exe/scripts), Metadata Template (IPTX, XMP)]
      - icon changes via double-click, icon resource reference (app.exe,0) could be set in .ini
      - improve arguments
      - add "Show in 'Open with' menu" checkbox to show in file context menu and in Custom filter (OR add separate checkbox for Custom filter)
    • remove 'Configure Programs' dialog from 'Open with'
      'Configure programs...' could open corresponding section in Settings
    • remove from Settings>Toolbar
      - buttons: 'Set command...', 'Set label...', 'Set Icon...'
      - commands: --COMMAND--, --NEW IPTC TEMPLATE--, --NEW XMP TEMPLATE--
  • unify storage
    keep stuff only in xnview.ini
    • default.bar
      - should only contain command names
    • xnview.ini
      - add new group, eg [UserCommands]
      - user command name must be unique
Example
Related
alee001
Re: User commands - rework
Post by alee001 »
Just passing by...
Sorry, this is just my personal opinion. As a super browsing tool, XnView MP is already quite good. Adding more customizable features would certainly be convenient for a few users, but for the general public, excessive features would make the system too complex or even redundant, and difficult to maintain.
alee001 wrote: Mon Feb 02, 2026 8:39 am Just passing by...
it seems to me that you may not have fully understood the suggestion I posted.
hint: it adds 0 new functionality, but fixes multiple issues
alee001
Post by alee001 »
user0 wrote: Wed Feb 04, 2026 1:37 pm
I apologize if any misunderstanding; I was simply pointing out that some functions were too complex.
