1.9.10: The browser does not respond to M key
Fleet Command
Post by Fleet Command »
XnView: MP 1.9.10 - 64-bit
OS: Windows 10 v22H2 x64
This is an old bug. (I've always wanted to report it, but I forgot. Nevertheless, it's reproducible in many past versions.)
Like most good file managers, XnView MP allows quick navigations to files folders via keyboard. Pressing a letter on the keyboard sends the cursor to the first file or folder that starts with that letter. Better yet, quickly typing a name sends the cursor to the file or folder that starts with that name.
XnView MP, however, has a bug: It ignores the M key. Quickly finding a file or folder that starts with M is not possible via keyboard.
Important: While carrying out the following steps, please allow one second time to pass between each step. (One second is so short that you probably don't have to do anything.) I can write a report without the one-second delay mandate, but it would become a complicated report.
  1. Open XnView MP, preferably without admin privileges.
  2. Ensure that your filter settings allow you to see all files and folders. (You can reproduce the bug without this step, but it's easier this way.)
  3. Navigate to C:\Windows. (You could do it in any other folder, but Windows is the one folder you definitely have.)
  4. Sort the folder by name.
  5. Set the folder view to "List". This will speed things up.
  6. Press C. Observe that the selection cursor jumps to "CbsTemp" (or something that begins with C).
  7. Press D. Observe that the selection cursor jumps to "debug" (or something that begins with D).
  8. Press E. Observe that the selection cursor jumps to "ELAMBKUP" (or something that begins with E).
  9. Press M.
Actual behaviour (bug): Nothing happens :bug:
Expected behaviour: The selection cursor must jump to "Media" (or something that begins with M).
Re: 1.9.10: The browser does not respond to M key
do you have shortcut M in Settings>Shortcuts?
Fleet Command
Yes. "M" is the viewer's shortcut for "Show alpha," but I didn't expect it to apply to the Browser mode, just like +, -, and *, which are zoom shortcuts.
Well... that was a shocking discovery, but thanks a lot for attending to the case. 🙏
do you have it in Browser too?
