1.10.1 Folders tree horizontal scroll bar disappear
erinqvnm
Post by erinqvnm »
Left: v1.9.10, Right: v1.10.1
Windows 11 x64
Scroll bar disappear, can't scroll horizontally.
Franky
Re: 1.10.1 Folders tree horizontal scroll bar disappear
Post by Franky »
No problem for me with Win 10 and 11, the scroll bar appears or disappears if I modify the width of the window.
erinqvnm
Post by erinqvnm »
In my case, the scrollbar disappear, and long folder replaced with ellipsis instead. Even worst, if I modify the width, the ellipsis doesn't follow. It leaves a blank.
jkm
Post by jkm »
Try renaming your XnView.ini file and restarting the app; see if the issue still occurs with the default .ini file.
erinqvnm
Post by erinqvnm »
Tried it, but the problem still occurs.
In my first screenshot, those are freshly installed (extracted). I'm using the portable zip for both v1.9.10 and v1.10.1. And set the Settings to Portable in Startup Wizard.
jkm
Post by jkm »
Pierre is going to have to chime in then. I haven’t seen anything like that. There are sometimes incompatibilities with things in the ini file, but if it’s doing it in a fresh portable copy, that is unusual.
Do you have any capability to test on a different computer, or in a VM?
erinqvnm
Post by erinqvnm »
Yes, tried it on 3 different computers. All have the same problem.
alee001
Post by alee001 »
I just tested the zip version1.10.1 on Windows 11 and it worked fine, maybe it's the installer version?
But strangely, when I check for updates using the v1.9.10 installer version, it doesn't find the latest version?!
Additionally, some old bugs from version 1.9.10 still exist…
erinqvnm wrote: Wed Feb 25, 2026 6:35 am Yes, tried it on 3 different computers. All have the same problem.
I've sent you a PM
This problem is supposed to be fixed in XnView MP 1.10.2. Please check and confirm the bug fix here.
