1.10.3: preview video and segmentation fault
tenaka18
Post by tenaka18 »
Subject: 1.10.3: preview video and segmentation fault
XnView: MP 1.10.3 - 64 bit
OS: Linux - 64bit
i was renaming one of my video freshly downloaded from whatsapp statuses.
Effect: the program crashed ( segmentation fault )
1. disable preview video autoplay ( F12-> miscellaneous-> disable preview autoplay ).
2. go to the directory containing more than one video.
3. if the preview shows a frame from the video, there is no problem and it works as expected.
if the preview shows a black frame, press the arrow down to go to the next file and the program will crash with segmentation fault
Actual behaviour (bug): navigate the directory containing more than one video file , press the arrow down to go to the next file and the program will crash with segmentation fault.
Expected behaviour: can navigate the directory , file by file with arrow down and every file has a preview.
QMDKWidget setMedia /home/utente/Video/Troie/SaraTruceRoma/Sara_Truce_Roma-000002.mp4
libva info: VA-API version 1.22.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_22
libva error: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so init failed
libva info: va_openDriver() returns 1
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: va_openDriver() returns 0
Segmentation fault
mediainfo output of the video file with the problem.
General
Complete name : Sara_Truce_Roma-000001.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/isom)
File size : 1.18 MiB
Duration : 3 s 533 ms
Overall bit rate : 2 813 kb/s
Frame rate : 30.000 FPS
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings : 1 Ref Frames
Format settings, CABAC : No
Format settings, Reference frames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 2 810 kb/s
Width : 960 pixels
Height : 720 pixels
Display aspect ratio : 4:3
Rotation : 90°
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.136
Stream size : 1.18 MiB (100%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Re: 1.10.3: preview video and segmentation fault
do you have problem with only some of mp4?
tenaka18
Post by tenaka18 »
xnview wrote: Fri Mar 06, 2026 9:01 am do you have problem with only some of mp4?
yes, i did send those files to you by private message here on the forum, to try for yourself and to debug it.
i also noted another thing, those files don't work with the integrated video player.
tenaka18
Post by tenaka18 »
the 1.10.5 version is affected, same error same result.
cheers
Please try to change in xnview.ini
useInternalVideoPlayer=false
