v1.10.5 (Win) There are issues with merging images
alee001
Post by alee001 »
1) After entering edit mode, saving or saving as does not return to the original path.
2) Why is the merged image named "strip#" instead of renaming it according to the first or last image among the multiple images?
Re: v1.10.5 (Win) There are issues with merging images
alee001 wrote: Thu Mar 19, 2026 2:43 am 1) After entering edit mode, saving or saving as does not return to the original path.
what do you means? Please describe the way to reproduce.
it's the template used...
alee001
Post by alee001 »
xnview wrote: Tue Mar 24, 2026 3:16 pm
1)For the same issue, please refer to case 1 in the previous post:
viewtopic.php?t=50346
2)Renaming the template name will affect the file sorting and make it difficult to find. If splitting images can be done by changing the name, why can't merging images be done?
alee001 wrote: Tue Mar 24, 2026 3:55 pm 1)For the same issue, please refer to case 1 in the previous post:
https://newsgroup.xnview.com/viewtopic.php?t=50346
dont re-create post for same bug
Could you describe your problem?
alee001
Post by alee001 »
xnview wrote: Wed Mar 25, 2026 11:08 am
1)If the reference you receive is a duplicate post, then I'll rewrite the question: :x
After setting up the image merging and entering edit mode, the save location is not the original folder path, but a previously opened folder. Closing the program and trying again doesn't resolve the issue.
2)Assuming the original images are a.jpg and b.jpg, and the merged template name is strip2.jpg, how do I find it among many images with different names?
its better to use template with date+time "Strip_yyyy-MM-dd_hhmmss"
same for clipboard pasting
alee001
Post by alee001 »
2) Image a.jpg is split into two, with template names a_1.jpg and a_2.jpg, and placed at the end. Pressing F5 will update them and place them after the original image. Similarly, when merging a.jpg and b.jpg, why can't the template name be a_b.jpg but strip#.jpg? This makes it very difficult for users to operate.
