1. Wrong dialog is shown "JPEG lossless rotation..." instead of "...crop...".
2. 'Crop' item in toolbar button "JPEG lossless transformations" is greyed out even if selection is created. In menu it's OK.
3. (Minor) New shortcut - ctrl+shift+y is missing in all menus with (lossless) 'Crop'.
BTW "JPEG lossless transformations" item is missing in the context menu, it would be usefull esp. in fullscreen.
XnView 1.82 <x>
RC3: JPEG lossless crop - 3 bugs
Dreamer
ckit
Dreamer
Re: RC3: JPEG lossless crop - 3 bugs
Don't know, maybe it's easy to fix, at least first two bugs should be fixed IMO, but Pierre must decide.Dreamer wrote:1. Wrong dialog is shown "JPEG lossless rotation..." instead of "...crop...".
Bug #2 has been fixed, #1 (and #3) not.
Postponed, now i don't modify source code...Dreamer wrote:Don't know, maybe it's easy to fix, at least first two bugs should be fixed IMO, but Pierre must decide.Dreamer wrote:1. Wrong dialog is shown "JPEG lossless rotation..." instead of "...crop...".
GeorgD
JPEG lossless crop - UI bugs
#1 and #2 are fixed in v1.96.5xnview wrote:Postponed, now i don't modify source code...Dreamer wrote:Bug #2 has been fixed, #1 (and #3) not.Dreamer wrote:1. Wrong dialog is shown "JPEG lossless rotation..." instead of "...crop...".
#3 still applies.
Moreover I found #4: In Menu, J is not underlined, so accelerator key is not shown but working - also applies to most other entries in Tools-menu.
Moreover I found #5: In F1 help, other hotkeys are shown than in xnview menu (that also really work, elsewise CTRL+Y would be defined for redo (as usual in german windows) and crop), see http://yfrog.com/5k20091023xnview196p Maybe this is dependant on used windows locale?
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
GeorgD
Still same situation in v1.97
