Alt+PgUp, Alt+PgDn error
ufoismey3k
Post by ufoismey3k »
Subject: 1.10.5 64-bit (Mar 15 2026) : Alt+pgup,Alt+pgdn error
XnView: MP 1.10.5 64-bit (Mar 15 2026)
OS: Windows Libformat 7.232 (Windows)
<Short description of the problem.>
Effect: When I changed the settings from using PgUp/PgDn to switch between files to using Alt+PgUp/Alt+PgDn for navigating to previous/next files, the program failed to correctly distinguish between PgUp and PgDn. Regardless of whether I scroll up or down with the mouse wheel, it always moves to the next file.
1. PgUp/PgDn = Page Up/Page Down keys
2. switch Alt+
3. ...
Actual behaviour (bug): <Current wrong behaviour of XnView> :bug:
Expected behaviour: <Expected, correct behaviour of XnView>
I expect scrolling up to go to the previous file and scrolling down to the next file.
Re: Alt+PgUp, Alt+PgDn error
you have changed Wheel ALT => 'Previous/next file'?
alee001
Post by alee001 »
Just passing by…
I think there's a problem with the list design options. Would you expect the settings shown in the image below to work?
ufoismey3k wrote: Fri Apr 10, 2026 11:00 am Expected behaviour: <Expected, correct behaviour of XnView>
alee001 wrote: Wed Apr 15, 2026 5:25 am Just passing by…
forum's official languages are English and French (in a dedicated subforum)
so use English UI in screenshots unless your questions concern translation
ufoismey3k
:bugfixed: 感谢你们的回复。
幸好现在的AI技术非常好。我的疑问都可以比较好的表达出来,你提出的意见很好。我用英语的截图可能会更加便于你们理解。
请你们设置到我截图的Alt+PgUp和Alt+PgDn为上一个文件/下一个文件的方式后。
看看你们能不能复现出我说的问题,就是无论我上划滚轮还是下划滚轮都是下一个文件。
谢谢你们耐心的回复。
"Thank you for all your reply.
Fortunately, current AI technology is excellent, which helps me express my issues clearly. Your suggestions are very helpful. I will use English screenshots, as they might be easier for you to understand.
Could you please set the shortcuts for ‘Previous File’ and ‘Next File’ to Alt+PgUp and Alt+PgDn respectively, just like in my screenshot?
After making these settings, please see if you can reproduce the issue I mentioned: whether I scroll the mouse wheel up or down, it always switches to the ‘Next File’.
Thank you for your patience and support."
ufoismey3k
xnview wrote: Tue Apr 14, 2026 9:19 am you have changed Wheel ALT => 'Previous/next file'?
Yes。
I can reproduce
Alt+Wheel scroll Up/Down
  • in Viewer (with OPs settings)
    it always navigates to the next file
  • in Browser (with default settings)
    it always scrolls down
user0 wrote: Thu Apr 16, 2026 7:34 am I can reproduce
This problem is supposed to be fixed in XnView MP 1.11.1. Please check and confirm the bug fix here.
