Difficulty downloading versions
dcwebman
I have always had problems downloading new versions of XnView. I am using Windows 11, and today, after trying on 2 different computers and both Chrome and Edge, I decided it was time to ask. I tried downloading both the EXE and Zip, but both fail after some time trying to download it with the following error:
Download.xnview.com took too long to respond.
Try:
Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT
Is there a special way to download new versions?
Try:
Jeff
Jeff
Re: Difficulty download versions
Do you have a way to view your internet connection speed, and also the actual download speed while downloading XnView MP?
If not, maybe search for something like 'windows view connection speed' and 'windows view download speed' for simple apps you might install.
dcwebman
Re: Difficulty downloading versions
Thanks for the reply. Download speed isn't the issue as I have no problems downloading other files and can also download XnView from other sites like Softonic. Speeds to download are around 500 Mbps. I have always had issues with downloading XnView, and it's the only one that has problems.
Jeff
Jeff
from which country?
dcwebman
dcwebman
Hi Pierre,
Your question prompted a thought. I added a VPN and set it to France. Then I had no problem downloading the latest file. Is this an expected issue?
Thanks.
Thanks.
Jeff
Jeff
strange, always the problem?
dcwebman
Hi Piere,
Sorry for the delay, but I didn't get a notification you replied. Yes, always a problem. I just opened XnView and was prompted there was a new version 1.11.5. I tried to download it and the same issue occurred. I had to use my VPN to say I was in France and then it downloaded without a problem.
Thanks.
Thanks.
Jeff
Jeff
VoodooManiax
Hi Pierre,
i've the same Problem here in Germany. I'm unable to DL any Version of XNView. Try to DL the File with different Providers (Vodafone, Telekom). No Chance. The DevTools in Chrome shows me a
Also tried to DL with WinGet. Same Problem.
But if i use a VPN (Land NL), i'm able to download the Setup File.
I think, we are not the only users with this Problem.
THNX 4 help.
Regards
VoodooManiax
. When i make a NSLOOKUP, the correct Server IP is shown.NS_ERROR_NET_RESET
THNX 4 help.
Regards
VoodooManiax
could you send me your IP by PM?VoodooManiax wrote: Wed Jul 29, 2026 9:39 am i've the same Problem here in Germany. I'm unable to DL any Version of XNView. Try to DL the File with different Providers (Vodafone, Telekom). No Chance.
@Pierre: I have sent you a PM.
@VoodooManiax: I have sent Pierre the IP of your last post, visible to me with my moderator rights.
i've sent you a PM
Nothing received...
sorry PM to @VoodooManiax & @dcwebman
VoodooManiax
Hi Pierre (@xnview),
Quick update from my side: The download issue on download.xnview.com still persists.
Whenever I try to download any version from the main domain, the connection gets blocked/dropped (likely an IP block, Geo-IP restriction, or CDN/WAF false positive). Testing via different German ISPs (Telekom / Vodafone) yields the exact same result.
Downloading only works when routing the traffic through an external proxy/VPN outside the affected IP pool.
Could you please check if there is an active firewall/fail2ban rule or CDN blocking range for German IP segments on the download server?
Thanks for your help!
VMX
VMX
