1.11.2 Failed to saving AVIF
dsausage
Subject: 1.11.2: Failed to saving AVIF
XnView: MP 1.11.2 - 64-bit (zip)
OS: Windows 11 - 64-bit
Cannot convert any type to AVIF,
Instant failed , sometimes crash
viewing AVIF is fine,
and convert to BMP/JPG/WEBP...are fine, only failed at AVIF.
1. View any support type img files (BMP/JPG/etc)
2. Tools -> Batch Convert -> set Format to AVIF
3. Press Convert
Actual behaviour (bug): Failed, log says "Saving error", Sometimes MP crashes.
3. Press Convert
Re: 1.11.2 Failed to saving AVIF
steps to reproduce?
dsausage
just simply convert any type to AVIF,
tried disable all options and different settings, all failed
win11 up to date,
9700x 64G ram
and ZIP version of XnviewMP
win11 up to date,
9700x 64G ram
there is save error and sometimes crash when you trying to save large image (~18k) at certain AVIF settings
what are the output dimensions of your images?
same issue if you save image as AVIF from Viewer via File>Save as ?
also show screenshots:
- Batch convert > Actions (if you have any action there)
- Batch convert > Output tab
- format's 'Write settings' (press 'Settings' button in Batch convert > Output tab - Format group)
dsausage
Thanks for reply!
if you asking the original img, it's 1300x1000x24 49.09KB
if you asking the output result, it's none file output.
oh this works, it saves successfully!
1.file at the D:\
2.batch settings:
3.Writing settings: (tried change all values, same issue)
4.result:
1.file at the D:\
2.batch settings:
4.result:
I cannot reproduce
if app generates dump file on crash - submit it via report form or zip and attach here
gyoical
Having the same issue
dsausage
I might found the problem is
I have an old-version MP, It has plugins\dav1d.dll
It doesn't exist in 1.11.2
I put it in plugins of 1.11.2 and the batch-convert works again.
FYI
FYI
you have it in main folder, i've tried on Win11 and no problem
dsausage
Thx for the info, it's newer version in main folder
but in my case I must move it to plugin else it won''t work tho.
masterjp
I can confirm the batch conversion error with the avif file format under Windows 11 (latest updates).
I did a clean install in a fresh directory to check this problem.
XnViewMP can save pictures in avif format with the 'save as' dialog. It works correctly.
But batch conversion does not work. The log file says saving 'test.avif failed'.
The successful solution is to move the dav1d.dll to plugins subfolder to prevent problems.
I also recognized, that there are 2 dll files with the same version and filesize, but different names.
I have a dav1d.dll and libdav1d.dll. Both have version 1.53.
Maybe different librarys need them with different names? E.g. ffmpeg or other libs?
Another strange thing is the avif filesize with the batch conversion and save as dialog.
Maybe both use different avif encoders? I get totally different filesizes with 100 kb dfiference.
This problem is supposed to be fixed in XnView MP 1.11.4. Please check and confirm the bug fix here.
