Batch delete a keyword
ChasZuck
Post by ChasZuck »
Is it possible to batch delete a keyword? Tried finding away but could not. So, I did one files at a time. I am sure there is a better way.
Franky
Re: Batch delete a keyword
Post by Franky »
You filter your images by the keyword you want to delete then remove the keyword from your selection.
ChasZuck
Post by ChasZuck »
Thank you, I will try that.
If there were 5 files that have that keyword, do I only remove it in one file and then select write to all files? I looked at several videos on metadata but did not see any on removing keywords.
Post by michel038 »
If you use "edit iptc" or "edit xmp" dialog, there are some settings to adjust in the last tab before trying to remove a keyword in a set of photos...
If you are using "Categories" pane, select chosen files and un-tick the category, and release selection.
