Auto zoom setting behavior
teslasystems
Post by teslasystems »
Could someone please clarify, how 'Auto zoom' setting works?
I want small images to display as is, while larger images to fit to window. So, I've chosen 'Fit image to window, large only'. But all images are displayed at 100% zoom, doesn't matter if they are small or large. What images are considered as "small" and what images are considered as "large"? Looks like this option doesn't work at all and has the same effect as 'No fit'.
Version: XnView MP 1.11.2 [10051], Win 11
Re: Auto zoom setting behavior
'Lock zoom' could be enabled (menu items with icon have no enabled/disabled state indication)
teslasystems
user0 wrote: Wed Jun 10, 2026 9:46 am 'Lock zoom' could be enabled (menu items with icon have no enabled/disabled state indication)
In my case it's disabled.
share your xnview.ini
teslasystems
user0 wrote: Wed Jun 10, 2026 9:51 am share your xnview.ini
Replaced some parameters with [removed], especially arrays, I'm not sure what was encoded in them.
there is no issue, 'Fit image to window, large only' works as expected
small image - when image is smaller than window size
large image - when image is larger than window size
teslasystems
user0 wrote: Wed Jun 10, 2026 10:29 am there is no issue, 'Fit image to window, large only' works as expected
If the logic is like that, then it doesn't work anyway. I've opened an image that is much larger than a window size and it's still 100% zoom, it doesn't fit to the window.
I cannot reproduce your issue with your ini
start from clean settings by renaming xnview.ini, 'Fit image to window, large only' will be the default mode
