[1.11.2] 'Settings button’ disappears from the screen
ctlu999
Post by ctlu999 »
XnView: MP 1.11.2 [10040] 64-bit (Apr 30 2026) - Libformat 7.239 (MacOS)
OS: MacOS 26.5.1 - 64bit
MacBook Air(15-inch,M3,2024 )
The Buttons of Settings disappear from the bottom of the screen.
Effect: Unable to see and click the CANCER or OK buttons.
1. MacOS > Menu Bar > (Apple icon) > System Settings... > Displays > Larger Text (1024 × 663) > Change Resolution
2. XnViewMP > Preferences... (Settings)
Actual behaviour (bug): 2 buttons get out of the screen.
Guess it cause by the ’Forehead’ of MacBook.
Because the Settings window display under the ’Forehead’.
Expected behaviour: Set the SettingsWindow to automatically resize to a smaller size.
jkm
Re: 1.11.2: ‘Setup’s Button’ disappear from the screen.
Post by jkm »
Have you tried dragging the edges of the settings window to resize it?
ctlu999
Re: 1.11.2: ‘ Settings Button’ disappear from the screen.
Post by ctlu999 »
It can drag the edges left and right, but not work on the top and bottom.
But it can be double-clicking the window header to automatically resize it to fit the screen, then the 2 buttons Visible now.
Thank you for helping to solve this problem.
