1.11.5 - batch rename - drag&drop and sorting
XnViewMP 1.11.5
Windows11 (25H2), display resolution 3840x2160, win scaling 150%
Batch rename
few issues after drag&drop files from file explorer
to reproduce
1. change sort order in Browser, eg to by File size
2. select few files in Browser and press 'Batch rename...'
files added in a desired order - OK
3. enable name template with any value
4. grag&drop few more files from win file explorer
issue A
'New name' column is blank
issue B
sorting is not applied
issue C
5. select any file(s) and try to manually change its order
nothing happens
issue D
3. select any file and press Remove button
file will be removed, but it will remain visible in the Preview
once you click a column header, it is not possible to return to Browser sort order (if it is not by Name)
  • add triple state sort order when Browser order is not by Name
    eg when clicked on any header
    -- 1st time - use header order Asc (↑)
    -- 2nd time - use header order Desc (↓)
    -- 3rd time - return to Browser order (remove indicator)
Related
Re: 1.11.5 - batch rename - drag&drop and sorting
currently adding files in rename dialog is not supported...
