Unable to rename files
Daan
Post by Daan »
I can't rename the files, when I manually sort the files. Up and down does't work.
Re: Rename files
Daan wrote: Tue Jul 07, 2026 5:05 pm I can't rename the files, when I manually sort the files. Up and down does't work.
You wish to view files in the browser in a different sort order, or permanently rename them?
If you are reporting a bug please describe the problem and provide steps to reproduce, if the issue is related to the order in which files are displayed please post again in the XnView MP - General Support forum section.
DuncanL
Re: Unable to rename files
Post by DuncanL »
If I understand the original message correctly; I think it's the same issue I'm seeing - the ability to sort images when renaming has stopped working:
The re-order buttons do nothing. They were definitely working fine a while ago as I use the feature fairly frequently, and when I tried yesterday it wasn't working.
jkm
Post by jkm »
I've made a bug post about it it.
Duncan's right, those buttons are completely broken.
This thread should probably be moved to MP-General; too vague for a good bug report.
jkm wrote: Mon Jul 13, 2026 11:43 pm I've made a bug post about it it.
this thread already contains all the information required to fix the bug
there is no need to create a duplicate with DuncanL's image
