👍[v.15/07] Resize parameters [work in v19]
Kadet
Post by Kadet »
When the image is resize, I would like to choose the target file type and compression parameters (for non-PNG). Necessarily!
By the way – I hope that the jpegli codec is used to create JPG files :)
Re: [v.15/07] Resize parameters
so same parameters as 'Convert', right?
Kadet
Post by Kadet »
xnview wrote: Thu Jul 16, 2026 7:12 am so same parameters as 'Convert', right?
Yes.
please check v19
