[Fixed] V1.0 (18) - small and bigger bookmark icon with same function [Fixed]
masterjp
Post by masterjp »
I used the album view and navigate to a folder with many pictures. I could add the folder as bookmark with both small and big bookmark symbols.
It's a little confusing when you have two similar icons of different sizes right next to each other. They're located in the upper-right corner.
Kadet
Re: V1.0 (18) - small and bigger bookmark icon with same function
Post by Kadet »
I only have one bookmark symbol.
masterjp wrote: Thu Jul 16, 2026 7:39 pm I used the album view and navigate to a folder with many pictures. I could add the folder as bookmark with both small and big bookmark symbols.
yes, if you group files. Perhaps hide the first one if you are using grouping?
masterjp
Post by masterjp »
I tested the behaviour again in version V1.0 (20).
I have disabled grouping (= setting none) in album view and see a small and big bookmark symbol.
If I start folder view only one bookmark symbol will be visible.
masterjp wrote: Fri Jul 24, 2026 8:20 pm I have disabled grouping (= setting none) in album view and see a small and big bookmark symbol.
could you post a screenshot?
masterjp
Post by masterjp »
Actually I installed version 1.0 (21) and everything is fine! :D
I am sorry.
