I noticed the GPS time looks wrong. The value for hours is displayed in both hours and minutes and the value for minutes is displayed to seconds. See sample below:
Detail view - GPS time is wrong [Fixed]
B.Douille
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
Re: Detail view - GPS time is wrong
B.Douille
Voici 2 fichiers exemple, d’origine.
Appareils différents mais même résultat pour les 2 avec v1.0 19
https://www.grosfichiers.com/bjUFiatpKy3
The GPS datas are cleared in these filesB.Douille wrote: Thu Jul 23, 2026 5:40 pm Voici 2 fichiers exemple, d’origine.
B.Douille
Sorry for that. Here is a new link, content verified.
https://www.grosfichiers.com/HGcq3uRrbTS
I had to zip the original files to ensure the GPS data is safe. I tried 2 times through 2 different services but the result was crap. The GPS data was set to 0. I don't know if it’s Android or the service providers. To upload I selected "Files" rather than "Pictures", I thought this method would preserve the file name, I never thought the process would destroy metadatas.
PS: I tested with v 1.0 20 just in case but I saw it's not fixed yet.
in your file 20250619_154331_Sony-XZ2_D.jpg, i can see GPS timestamp: 13:43:31 and EXIF modified: 15:43:31. Exiftool shows the sameB.Douille wrote: Fri Jul 24, 2026 11:10 pm PS: I tested with v 1.0 20 just in case but I saw it's not fixed yet.
B.Douille
The files I sent are originals. Actual date/time is visible as timestamp in the filename. For the file you mentioned it is 15:43:31, you are right.
The problem is XnView mobile shows 13:13:43 as GPSTimeStamp. It's not due to a change made by the app, it's misinterpretation of the bytes in the metadata :
13 h is correct (UTC +2 in summer for my location)
13 m is wrong, just a copy of the previous number
43 s is wrong as well, comes from the minutes
It’s another file but same issue as per my initial message
Please check v22B.Douille wrote: Sat Jul 25, 2026 3:08 pm It’s another file but same issue as per my initial message
B.Douille
Re: Detail view - GPS time is wrong [Fixed]
Fixed !
Thanks Pierre. I really start to use it on a daily basis
