is it possible to create thumbnails from movies?
Deffe
Post by Deffe »
Hi
Is it possible to create Thumbnails from a movie using the commandline somehow. I got a website that needs to create thumbnails for movies.
I saw this nconvert program and started woundering if your program is able to convert movies aswell to thumbnails?
Thanks.
Richard A
Re: is it possible to create thumbnails from movies?
Deffe wrote:Hi
No, but perhaps a good option for nconvert
Deffe
Post by Deffe »
How sad :(
It would have been greate with that sort of option since I have searched the webb for weeks without finding a good working and easy to use converter.. All I found was ffmpeg and that one does not work with wmv files version 9.0+ and a couple of other formats.
Do you think there will be anything upcoming soon in this matter? I would gladly test it out.
My mail is [email protected]
Deffe wrote:How sad :(
Is it urgent?
Oliver
Post by Oliver »
Hy,
i need also thumbnails from videos.
Best regards
Tom
ckit
Post by ckit »
Media Player Classic 6.4.8.8v2 can do this.
