v26 - rating of pictures in jpegxl and heic format are unsupported
masterjp
Post by masterjp »
I checked my camera folder with different heic format picture files (samsung s23 plus), which use jpeg or heic format.
I try to rate my heic format photos and xnview skipped the file with the info: unsupported file format.
jpegxl files are also unsupported picture files for the rating feature.
How does the rating feature work? Does it save the rating within the meta data of the picture file or use a separate database for rating informations?
Re: v26 - rating of pictures in jpegxl and heic format are unsupported
masterjp wrote: Mon Aug 03, 2026 7:58 pm How does the rating feature work? Does it save the rating within the meta data of the picture file or use a separate database for rating informations?
Currently the rating is saved in metadata of the file. Not sure on android it's good to use the database to save rating...
For HEIC i use the Android API, but very limited. I'll use libheic later...
It works here, please send me a jpegxl sample?
masterjp
Post by masterjp »
Here is a test heic file directly from samsung s23 plus smartphone (firmware from july 2026). I reduced the original filesize (3.3 MB) with xnviewmp for windows to 1.6 MB to prevent the upload limit of 2MB.
I converted this file with xnview mobile to jpegxl (85% quality). This jpegxl I could not rate.
I did some further tests with older heic format files from my samsung s23 plus camera. The older heic pictures do not make any problems during rating. That is strange. I am not sure, if samsung has changed the heic file format during the last months with the latest firmware updates.
Test_HEIC_Rating.zip
Kadet
Post by Kadet »
In v27 I can rate JXL and HEIC files.
masterjp wrote: Tue Aug 04, 2026 12:59 pm Here is a test heic file directly from samsung s23 plus smartphone (firmware from july 2026). I reduced the original filesize (3.3 MB) with xnviewmp for windows to 1.6 MB to prevent the upload limit of 2MB.
Thanks but a jxl sample file please. Currently i use the HEIC engine from system, i'll add my own engine soon
masterjp
Post by masterjp »
I could not directly upload the heic file, so I uploaded a zip file which contain a heic file!
See my previous post. There is a link to the file.
Kadet
Post by Kadet »
masterjp wrote: Wed Aug 05, 2026 12:48 pm I could not directly upload the heic file, so I uploaded a zip file which contain a heic file!
I think Pierre is asking you for a sample of a JXL file, not an HEiC file.
masterjp
Post by masterjp »
@Kadet: Thank you.
JPEG XL Testfile with rating problem - File was converted from HEIC format to JPEG XL by xnview mobile v27.
Tesfile_jxl_samsung_s23_converted_by_xnview_mobile.zip
Please check v28
masterjp wrote: Wed Aug 05, 2026 2:12 pm @Kadet: Thank you.
is it good?
masterjp
Post by masterjp »
I tested it again with v32.
JPEG XL rating works now! Thank you. :D
HEIC format files can not be rated. :bug:
