SE: hotkeys - question - for Pierre
Dreamer
Post by Dreamer »
Is it possible to use different actions for LMB, MMB, RMB, or even wheel up/down? I mean if I press any mouse button in context menu on thumbnail/other item.
Limited...
:arrow: Dreamer
:) Hi !
- Unfortunately, the most mice we have noawadays are using a maker's setting-soft + driver, hence this soft¦driver takes precedence, and combinations you could wish using the MB (all) would't work in the most cases…
- In example, here my Logitech® mouse ignores totally the new short cuts with the mouse-buttons combinations…
:mrgreen: KR
Dreamer
Re: Limited...
Post by Dreamer »
Clo wrote:- Unfortunately, the most mice we have noawadays are using a maker's setting-soft + driver, hence this soft¦driver takes precedence, and combinations you could wish using the MB (all) would't work in the most cases…
There are no special commands for other MB in ShellEx now.
Clo wrote:- In example, here my Logitech® mouse ignores totally the new short cuts with the mouse-buttons combinations…
That's because you (probably) don't use MMB as MMB, but for a special command.
Imposssible to free---
—> Dreamer
:D Hello !
- Indeed, the middle-click is used for the auto-scroll (gesture style). The snag is that I've a pretty bunch of options for this middle-click… except “Do nothing" ! Or something similar, making the button available for apps. and their short cuts… It could be the same with other makers' softs…
:mrgreen: KR
Dreamer
Re: Imposssible to free---
Post by Dreamer »
Clo wrote:—> Dreamer
:D Hello !
:mrgreen: KR
Could you place some screenshot of possible actions for your MMB please?
I'll suggest options that would be good also for mouse with 2 buttons. I just need to know if I can suggest also more possibilities - Pierre?
Dreamer
Re: SE: hotkeys - question
Post by Dreamer »
Dreamer wrote:Is it possible to use different actions for LMB, MMB, RMB, or even wheel up/down? I mean if I press any mouse button in context menu on thumbnail/other item.
Pierre could you tell me please? I want to suggest something, but I need to know this.
SE = Shell Extension :wink:
No, i have no way to know if it's LMB, RMB or MMB....
Dreamer
Post by Dreamer »
OK, now mouse wheel works as 'hide/close' context menu, so enough maybe...
