How can I disable the drag and drop feature?
Berti
Post by Berti »
Hi.
According to this thread we should have a confirmation dialogue for drag&drop operations since 2024:
viewtopic.php?t=45990
Where is this feature? I cannot find any option for that.
The drag&dop "feature" of XnView MP is a huge pain for me!!
  • It does not have any confirmation dialogue.
  • It reacts directly to the right mouse button and the slightest drag.
  • It reacts to other mouse buttons (for example forward/backwards).
  • It reacts to clicks and slightest drags of other folders and moves random folders there without any warning.
  • There's no undo function (for example suggested here: viewtopic.php?p=207276).
Example behaviour see video attached!
(XnView MP 1.11.5 [10169])
In my opinion, that's a HUGE problem. I accidentally moved several folders because of this strange behaviour. And if you don't notice it you will never find your files again.
Please fix this!
Re: How can I disable the drag and drop feature?
user0 wrote: Sun Oct 27, 2024 3:30 pm done in 181 via [Browser] noDrag=true
maybe add new context menu option for convenience, eg 'Draggable' or 'Enable Drag&Drop'
add highlighted into corresponding section of xnview.ini file
Berti
Post by Berti »
Alright, that works. Thank you.
Anyway:
  • Why is this still no simple option in the settings menu?
  • The default faulty behaviour seen in the video should be fixed anyway.
