Hot Folders on v1.115.0 ARM64
michaelp42
Updated to the latest version, and the "watch hot holders" button seems to have vanished. However it still seems to recognise it, but instead of processing just new images, it does everything in the folder, which for me can be 100's of images, so it takes a while. Is there a way to turn off looking for new images??
Re: Hot Folders on v1.115.0 ARM64
I don't see a way to designate a folder as a Hot folder, or to enable/disable hot folder operation in which files arriving in a designated folder are processed immediately in parallel with normal batch processing when enabled?
michaelp42
There was in the previous version, and it seems to have still remembered that, but with now no way to change it. It used to work rather well, now not so much.
'watch hot folders' is always here
But what if a user wants to control when a hot folder is watched, to be able to pause monitoring?
And how to designate a folder as a watched folder?
you uncheck itcday wrote: Wed Aug 19, 2026 9:04 am But what if a user wants to control when a hot folder is watched, to be able to pause monitoring?
in 'hot folders...'And how to designate a folder as a watched folder?
Thanks, but like michaelp42 I have installed v1.115.0 and no longer see these options...
Have they maybe been moved??
A little problem, you need to select one filecday wrote: Wed Aug 19, 2026 9:37 am Thanks, but like michaelp42 I have installed v1.115.0 and no longer see these options...![]()
