v41 - picture conversion window - description: keep original
masterjp
Post by masterjp »
In the Conversion window, there is a checkbox labeled "Keep Original." I find the description is a bit misleading if you're not familiar with the program or don't work with images very often. Instead, I might rename it "META-DATA" or "EXIF Data."
Re: v41 - picture conversion window - description: keep original
It's not for metadata, but to keep original file
masterjp
Post by masterjp »
'Keep Original' mean original size or what do you mean?
masterjp wrote: Thu Aug 20, 2026 6:53 am 'Keep Original' mean original size or what do you mean?
'Remove original file' will be better?
masterjp
Post by masterjp »
Now I understand what you mean with 'keep original'. :idea:
I would describe it with 'keep original file'.
Then it's self-explanatory to me. :)
'keep original file' or 'Remove original file'? :)
Kadet
Post by Kadet »
I think if it's going to be confusing, maybe it's better if there was no choice and always kept the original.
masterjp
Post by masterjp »
People who work with images professionally or who are passionate about photography in their free time would never delete the original files after converting them. After all, the main reason for converting them is often to upload them more quickly to the Internet (including social media) or to share them with family, friends, acquaintances, etc.
ok, so for now, i hide it
xnview wrote: Thu Aug 20, 2026 8:34 am 'keep original file' or 'Remove original file'? :)
wording should be like this:
- remove - a non-destructive action that removes an item from the current list,collection,etc.
- delete - a destructive action that permanently deletes an item, eg a file
it is fine to delete the original as part of the workflow,
but the command should be 'Delete original', not 'Keep original'
