I would like to ask whether there are any plans to implement a feature that allows adding a background image to input files. In essence, this would be the reverse of the existing "Add Watermark" function: instead of superimposing a watermark onto each photo, the user could specify a background image, and each input photo would be placed as a foreground layer onto that background.
Thank you for considering this suggestion.
Feature Request: Adding a Background Image to Input Files
user6290
Re: Feature Request: Adding a Background Image to Input Files
duplicate
Batch convert 'Watermark' option - Add option to apply loaded images to a fixed background
Add custom background to pngs
user6290
I apologize for not making better use of the search function before posting.user0 wrote: Mon Aug 31, 2026 5:54 pm Duplicate:
So this feature request was already raised two years ago—but for some reason, it seems the developer hasn’t added it to the current version yet? At least in XnConvert 1.115, I don’t see any options like z‑axis offset or “use as background.”
Still, it’s very helpful to know that nconvert can achieve what I need. Thank you so much for your reply!
