Next features [Fixed]
Post by michel038 »
I suggest improving filters :
- Add an horizontal lifter (slider ?) for filters having a very long list of items, like tags
- Add a checkbox to enable and show content of a filter , or disable and hide the content; only filter name is shown.
- Add a + button for metadata to be used for filtering
Re: Next features
michel038 wrote: Tue Sep 01, 2026 12:30 pm - Add an horizontal lifter (slider ?) for filters having a very long list of items, like tags
yes will be useful
yes, perhaps better to a setting button at the top to enable/disable whichones do you want?
to make a global metadata filtering?
Re: Next features
Post by michel038 »
xnview wrote: Tue Sep 01, 2026 12:39 pm
Yes better with a button , same as those in "Settings"
I would like to choose a field, eg iptc:city , add this field with a "+" in the iptc metadata area ... (and a "-" button to remove other fields I don't need)
And then, open a dialog (same dialog as File > Name> ) to enter a criteria (is, is not ...) "Paris"
I remember Picasa used only global filtering. It's very efficient for beginners.
A single search field. You enter a text , Marseille , and all photos containing this word, anywhere, will be displayed.
Even for users who don't know anyting about metadata
Re: Next features
please check v50
Re: Next features
Post by michel038 »
I haven't tested all functions and versions, but I found great improvements in V1.50 for "Filter" and 'Search' functions.
1) Using "GALLERY" in main menu
Filters have been updated , a search field is shown to select an item in "Tags" or other fields with many values.(instead of a slider) OK !
All metadata can be used as a criteria OK !
Amazing.
- One more improvement could be the ability to edit 'recent' entries in the filter, perhaps with a long press on the entry. (adjust criteria without changing the field name)
- Also add a "Favorites" area, where the user could add his own favorites filters
- My photos contain these exif data :
exif:make="NIKON" and Model="COOLPIX"
Is there a way to filter on these fields, I can't get a match ...(no files found)
2) In the first search field of "Filter" , sometimes, values in metadata such as iptc:caption are found, sometimes not. Should I renew the database ?
Edit : Answer "Caption" field must be displayed as a label for thumbnails
3) But in "ALBUMS", and "FILE" choices in main menu, the previous version of filters is still used.
In Settings menu (top right of the "Filter" screen) The first three items don't show anything (File type, Year, Rating)
etc ...
B.Douille
Re: Next features
Post by B.Douille »
I support the idea
Same for me : make=samsung or sony don’t find anything, even just using the main search field aka any field (I can find some "sony" where it’s in the file name, that's it).
In search it works, not in filter.
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
Re: Next features
michel038 wrote: Sun Sep 06, 2026 12:33 pm - One more improvement could be the ability to edit 'recent' entries in the filter, perhaps with a long press on the entry. (adjust criteria without changing the field name)
Please check v51
etc ...
you have not the same filter view??
Re: Next features
Post by michel038 »
- Edit filter OK
- Exif make and model OK
- I noticed now that filters are adaptative : items depend on the content of the files shown ... Ok
B.Douille
Re: Next features [Fixed]
Post by B.Douille »
Looks fine now. Thks Pierre
