Show clipping
Show clipping
What do you think about 'show clipping' & histogram?
B.Douille
Re: Show clipping
I thought of this while testing the various adjustments. Having the same design than Curve for Exposure, Contrast,... would be useful. I think it can be always displayed. While testing the curve adjustments the size and position of the elements was ok. And we still have the possibility to zoom on a detail if need.
Even better if the graph shows saturation and cuts (loosing details on high light or shadow pixels). Clipping is the name, as per audio ?
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
Re: Show clipping
so Histogram&Clipping when editing an image (like curves)?
B.Douille
Re: Show clipping
Yes
Re: Show clipping
and what do you think if 'single tap' in fullscreen will show icons at top to show histogram/clipping and perhaps 'show info overlay'/back?
B.Douille
Re: Show clipping
I'm not sure there is a need at the moment. Maybe I'm not the one, not a professional photographer. I don't use to compare multiple pictures taken on the best exposure,... more on the content. I even don't understand what you mean by overlay/back
And, on the use of single tap we should think of consistency with videos.
Re: Show clipping
which options in compare tool?B.Douille wrote: Tue Sep 15, 2026 7:30 am Can we activate the options you suggest in the comparison tool ? Currently it's limited to 2 photos but could be expanded to many with such infos.
B.Douille
Re: Show clipping
histogram/clipping and perhaps 'show info overlay'/backwhich options in compare tool?
Re: Show clipping
Please check v59B.Douille wrote: Tue Sep 15, 2026 8:02 amhistogram/clipping and perhaps 'show info overlay'/backwhich options in compare tool?
B.Douille
Re: Show clipping
Looks good in V59
Can we do for a serie of picture, not only 2 ?
Still I don't see the difference, the usage of the info overlay'/back. I need a training, or a sample ?
B.Douille
Re: Show clipping
When only 2 pictures in the comparison tool, can we have a single graph showing the difference as we move the cursor ?
And, as suggested when multiple file are compared by sweeping left-right a single graph is necessary. Best if it can be moved on the screen, floating.
Re: Show clipping
what do you means?B.Douille wrote: Sun Sep 20, 2026 8:08 am When only 2 pictures in the comparison tool, can we have a single graph showing the difference as we move the cursor ?
B.Douille
Re: Show clipping
The single graph change as we move the cursor that displays (part of) file 1 / file 2.
To do so it should be based on the composite image displayed, not the content of the files.
Re: Show clipping
sorry which single graph?B.Douille wrote: Sun Sep 20, 2026 4:46 pm The single graph change as we move the cursor that displays (part of) file 1 / file 2.
B.Douille
Re: Show clipping
Since v59 the comparison tool shows 2 graphs, one for each picture. My suggestion is to have a single graph and make it show the curves progressively (or abruptly if not possible) as the user move the slider on the left or right.
On top of this, open the comparison tool to multiple picture. So the graph can be used to compare and select them, based on aspects and color/light balance.
If a seletion is made available, back on the thumbnails, selection could be used to delete, move, adjust,...
