XnView Classic 2.52.7
Dear user,
XnView Classic 2.52.7 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
https://download.xnview.com/XnView-win.exe (English Setup, Multi language)
https://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
https://download.xnview.com/XnShellEx.exe
https://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
https://download.xnview.com/XnShellEx64.exe
https://download.xnview.com/XnShellEx64.zip
SHA256 CHECKSUMS
____ 2.52.7 Changelog
* Lossless rotation - viewtopic.php?t=51363
* WinXP - viewtopic.php?t=51365
____ 2.52.6 Changelog
* Vulnerabilities fix - Jonas Zabel (Fraunhofer SIT)
* Vulnerabilities fix - Arvind S Raj, Ati Priya Bajaj and Siyu Liu from ASU SEFCOM
____ 2.52.5 Changelog
* Some bugs fixed
* NConvert: binary rotate 90 - viewtopic.php?t=50093
____ 2.52.2 Changelog
* NConvert: -xyb for JPEGli
____ 2.52.1 Changelog
* Libwebp 1.5.0
* Ghostscipt 10.05
* JPEG 2000 - encoding
____ 2.52.0 Changelog
* Old plugins removed from package
* NConvert: multipage and delete option
____ 2.51.7 Changelog
* GIF print - viewtopic.php?f=36&t=47348
* CVE - Thanks to Matteo Marini
____ 2.51.6 Changelog
* ICC
* TIFF CVE - Thanks To Eugene Lim
* CVE - Thanks to Junsoo Lee
* NConvert: Clear - viewtopic.php?f=57&t=46797
____ 2.51.5 Changelog
* HEIC not loaded
* LibWebP CVE
____ 2.51.4 Changelog
* TIFF crash
* NConvert: Bad output for TIFF LZW+Predict
* NConvert: Filelist - viewtopic.php?f=57&t=46034
____ 2.51.3 Changelog
* CVE - Thanks to Seyit Sigirci
* NConvert: HEIC (x64) - viewtopic.php?f=57&t=44026
* NConvert: TIFF 16 bits output with Predictor - viewtopic.php?f=57&t=44869
* NConvert: -keepcspace & big image - viewtopic.php?f=57&t=44789
____ 2.51.2 Changelog
* Export & extension missing - viewtopic.php?f=36&t=43430
* Argument in utf8 - viewtopic.php?f=36&t=44014
* Susie plugin - viewtopic.php?f=36&t=43887
* NConvert: longest/shortest & mm - viewtopic.php?f=57&t=44670
* NConvert: -recurse - viewtopic.php?f=57&t=43854
____ 2.51.1 Changelog
* CVE by Xu Peng from UCAS
* Minor fix
* NConvert x64 : JPEGXL & AVIF - viewtopic.php?f=57&t=43732
____ 2.51.0 Changelog
* WebP in Slideshow 'add folder' - viewtopic.php?f=36&t=42755
* QOI read support
* WebP 1.2.2
* NConvert: AVIF support - viewtopic.php?f=57&t=43096
* NConvert: Canvas resize & CMYK - viewtopic.php?f=57&t=42022
____ 2.50.4 Changelog
* TIFF crash
____ 2.50.3 Changelog
* Rotate dialog & show grid - viewtopic.php?f=36&t=42496
* Canvas resize on 1bit picture - viewtopic.php?f=36&t=39569
* FITS better support
* NConvert (Windows): Recurse support - viewtopic.php?f=57&t=42626
eg.: nconvert -o output/% folder
* NConvert: $DateModified - viewtopic.php?p=169286
* NConvert: Multipage output filename - viewtopic.php?f=57&t=42584
____ 2.50.2 Changelog
* Labels & tooltips can crash
* PNG crash
____ 2.50.1 Changelog
* Browser size not restored - viewtopic.php?f=36&t=42207
* Dialog always on Screen #1 - viewtopic.php?f=35&t=42147
* Context icon - viewtopic.php?f=34&t=42232
* NConvert: multiple -canvas & bgcolor
* NConvert: -jpegtrans - viewtopic.php?f=36&t=41826
* NConvert: -canvas longest 220mm - viewtopic.php?f=57&t=41812
* NConvert: jpegtrans exif & keepfiledate - viewtopic.php?f=57&t=42203
____ 2.50 Changelog
* APNG crash - viewtopic.php?f=36&t=41803
* JPEGXR RGB10
* CR2 orientation problem
* Ghostscript 9.54
* Recoil
* GEM vulnerability - Thanks to Michael Heinzl
* NConvert: -use_org_quality problem
* jpegtrans not written for NConvert - viewtopic.php?f=36&t=41826
* NConvert: -text_font name percent - viewtopic.php?f=57&t=41811
* NConvert: -canvas shortest/longest - viewtopic.php?f=57&t=41812
____ 2.49.5 Changelog
* Ghostscript detection
* TIFF - viewtopic.php?f=35&t=41136
* HEIF plugin - viewtopic.php?f=36&t=41104
* Old versions of ghostscript not recognized
* NConvert: -use_org_quality - viewtopic.php?f=57&t=41397
* NConvert: multiple text lines - viewtopic.php?f=57&t=41358
____ 2.49.4 Changelog
* Ghostscript 9.53.x
* GPS & file date - viewtopic.php?f=56&t=40971
* TIFF Security vulnerability (Thanks to Michael Heinzl)
* NConvert: -levels2 - viewtopic.php?f=57&t=40490
* NConvert: -resize supports cm/mm/inches
* NConvert: -autodeskew fixed
* NConvert: -noholder to disable %$ chars - viewtopic.php?f=57&t=40820
____ 2.49.3 Changelog
* Convert 16 to 256 colors - viewtopic.php?f=36&t=39421
* Disable ESC to close tabs - viewtopic.php?f=35&t=17078
[General] EscToCloseView=0
* Select file from search results & switching mode - viewtopic.php?f=34&t=40063
* Title empty when recurse - viewtopic.php?f=36&t=39979
* Resize - viewtopic.php?f=35&t=40248
* Slideshow: Order of files - viewtopic.php?f=56&t=40087
* Fortis Mag fix
* NConvert: -wmsize watermark percent size - viewtopic.php?f=57&t=38754
* NConvert: canvas size in inches/cm/mm - viewtopic.php?f=57&t=39361
* NConvert: replace_color - viewtopic.php?f=57&t=39769
* NConvert: -temperature added
____ 2.49.2 Changelog
* Problem with Ghostscript 9.50
* PDF font problem - viewtopic.php?f=36&t=39662
* CR3 - viewtopic.php?f=35&t=39478
* .sld must use 'Recurse' setting - viewtopic.php?f=35&t=39330
* GIF loop - viewtopic.php?f=36&t=31689
* PAM CMYK
____ 2.49.1 Changelog
* TIFF 16bits greyscale
____ 2.49 Changelog
* SQLite 3.29.0
* NConvert: greater_than/less_than condition - viewtopic.php?f=57&t=39147
* PSD: Error when writing metadata - viewtopic.php?f=57&t=39137
* Export - Problem with RGBA - viewtopic.php?f=36&t=39044
* Capture - viewtopic.php?f=36&t=38934
* Left/Right F11 to open fullscreen on Left/Right monitor
* Create multi file & folder with '.' - viewtopic.php?f=36&t=39008
* # to comment line in .sld file
* Multipage create: Check if output filename exists
* Slideshow crash when using animated GIF - viewtopic.php?f=36&t=38902
* XIM format import added
* Change timestamp must not use 12h format - viewtopic.php?f=36&t=38702
* GIF not played correctly in Slideshow - viewtopic.php?f=34&t=38303
* CVE - https://github.com/apriorit/pentesting/ ... ugs/xnview
* NConvert: -unsharp
* NConvert: -exposure - viewtopic.php?f=57&t=39136
* NConvert: -colorize h l s
* NConvert: Remove EXIF orientation -exif_rotation - viewtopic.php?f=57&t=38648
* [Rename]/TemplateStart, position of number in template - viewtopic.php?f=34&t=38568
* CVE-2019-12151
* ShellEx: 'Convert...' & input fields
