Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Installer
when app instance is running:
- installation (update) fails with 'DeleteFile, code 5' (Access denied) on some files (QtConcurrent.dll, mdk.dll, msvcp140_1.dll, etc)
- uninstallation leaves files undeleted
- add a running-instance check to Inno Setup
- (optional) add RestartApplications=yessame behaviour as running current installer with /CLOSEAPPLICATIONS flagCode: Select all
[Setup] AppMutex=XnViewMP_Running CloseApplications=yes RestartApplications=yes
