Settings - general - add theme management
XnViewMP 1.12.1
Windows11 (25H2), display resolution 3840x2160, win scaling 150%
Settings
Custom themes are not standardized and it is not possible to have multiple custom themes at once.
Examples of custom themes:
- Windows 11 Fluent (WinUI 3) dark theme for XnView MP 1.12+
- Windows 10 Dark & Light Mode Themes for XnView MP
- [Theme] Blender inspired theme for XnViewMP (incl. icons)
  • add theme management
    • filesystem
      - each theme should be in separate folder
      - allow icons to be set for all commands, not just those listed in default.bar
    • settings (eg like in ImageGlass)
      - add Appearance tab (in General or Interface) with theme management
      - add a [System/Light/Dark] mode selector with support for different themes per mode
  • add settings for further customization
    • size
      - font [75-200%], UI scale [75-200%], icons size [16,20,24,32,48]
    eg
    • folder structure
      ├── themes/
      │   ├── my-theme/
      │   │   ├── theme.json        # manifest + colors + metrics
      │   │   ├── style.qss         # optional stylesheet template
      │   │   └── icons/
      │   │       ├── commands/     # optional cmd_xxx.png ...
      │   │       └── overlays/     # optional
    • theme.json
        "name": "Midnight",
        "author": "You",
        "version": 1,
        "base": "dark",
        "colors": {
          "window": "#1e1e24",
          "panel": "#26262e",
          "text": "#e6e6ea",
          "accent": "#4c8dff",
          "thumbBorder": "#3a3a44",
          "selection": "#4c8dff55"
        "metrics": { "radius": 6, "iconSize": 20, "thumbSpacing": 8 },
        "iconTint": null
Example
  • ImageGlass
    1. download .igtheme from site (.json settings + .svg icons)
    2. 'Install' OR unzip in ..\ImageGlass\_themes\<NEW_FOLDER> & Refresh
    3. select from the list
Related
