Subject: does not start up
XnView: MP 1.12.x - 64 bit .deb
OS: Linux Mint /64bit
XnView does not start after update from 1.11.7 to any newer version. So 1.11.7 is the last version that works.
Effect: can not run XnView. Deleting and reinstalling does not solve the problem.
1. update to 1.12.0 or 1.12.1 .deb
2. try to run XnView
3. nothing will happen
Actual behaviour: won't run
Workaround: I went back to 1.11.7
Can not run XnView:MP 1.12.x .deb after update -LinuxMint
gekko7
Re: Can not run XnView:MP 1.12.x .deb after update -LinuxMint
Please see this very recent thread: Applied update and now xnview won't even open.
As a Linux Mint DEB user myself I normally delay installing new versions...
KevinSlater
Rolling back to version 1.11.7 seems like a sensible temporary workaround. Hopefully the developers can identify what changed in the newer Debian packages. It would also help to share startup logs and error screenshots when reporting the issue. https://www.filemail.com/ can help with larger diagnostic files.
